Bad Alternator??
Bad Alternator??
Well, first off Ill explain the background.
Ive had the car for a little over a year and Im currently on my 3rd battery. They are all quality batteries and always test good when put in the car. Every single time I get the Alt tested as well and it passes with flying colors. Charges at right at 14.4V and gets the green light.
Tonight I notice something. I turned on the A/C and the voltage drops from a tiny bit about 13 to almost the little yellow hash marks. I rev up the car and it goes back up to around 13. As soon as I start idling again the lights dim and the voltage dropped again.
Now, is this a pretty clear cut and dry dying alternator?
Hows that excitor wire doing? That could be the problem too.
I suggest getting a PepBoys Pro-Start brand. $149.00, Lifetime warranty. I have one and its great. Never drops off even at idle with the A/C blasting and my 1,000 watt system cranking with the headlights on. Not even a tiny little drop.
Also, if its not the alternator when you put it in, you can return it. Then look at the excitor wire.
Forgot to post this. Went and got it tested, here are the results.
Battery: 12.53 volts when running, 741 CCA
Alt: 13.8V with it loaded and unloaded. If Ive read correctly on here it should be around 14.4-6 while being loaded.
PepBoys can blow me with all of their garbage alternators. I went through about 4-5. And the workers there try to give me some bullshit about how the problem is with my car, and when I get it tested, it fails. I will never step into a PepBoys ever again. (I also did an "Electrical Check" while I was having the problem, guess what they said my car was OK. Wrong. Autozone, NAPA, or Advanced it is.
I replaced the wire that goes into the alternator, along with getting a new battery, and alternator. Problem fixed. I dont know the brand alt i have, but I went with an Optima Red Top.
GOOD
For the alternator, if you need it, go to Advance Auto then, they carry the same ones I believe. Lifetime warranty.
Get this and splice it in....use BUTT connectors that can be heated to shrink around the wire. DO NOT solder it on.
http://cgi.ebay.com/ebaymotors/LS1-A...Q5fAccessories
I dont think I will. I saw the wire coming in from the top but no way can I get to it from the top. Impossible for me with my long arms.
I might try to get it from the bottom. Until I finish moving its on the back burner unfortunately.
