Exhaust pipe size w/LS1 in a street rod??
Old 06-23-2009, 07:47 PM
Mike52's Avatar
Default Exhaust pipe size w/LS1 in a street rod??
I'm getting ready to build the exhaust for the '32 Coupe. What are the optimal size pipes to run on a stock LS1, 2¼" or 2½"? Due to frame rails, engine placement, etc, I'll be using block hugger headers if that helps with the sizing.
Thanks,
Mike
Old 06-23-2009, 09:34 PM
'00_Z's Avatar
If you plan to keep the engine stock 2.25" duals will flow fine. You can run 2.5" also if you want it louder but it isn't necessary.
Old 06-24-2009, 01:19 AM
WickedSuperSport's Avatar
well, LS1's come stock with 2.5" piping, so thats probably what you might want to use.
Old 06-24-2009, 03:19 AM
KurtRardin's Avatar
How big is the collector on your headers?
For the love of God, do not listen to the size recommendations that an exhaust shop makes either, unless it's a sponsor here. Most shops think that an LS1 is an ol' 350, and that the same rules apply. Most of the aftermarket exhaust systems for LS1s are 3", but 2.5 would honestly be plenty, especially if its just going to be a cruiser.
You will know that your shop hasnt got a clue about LS engines if they mention their little catch phraze: "Back Pressure"
Old 06-26-2009, 07:44 PM
Mike52's Avatar
Default Thanks
Thanks to everyone.
Kurt, I won't be listening to an exhaust shop, I'll be the one fabbing this system. I've got a great, cheap (free) source for the stainless steel tubing including the bends, elbows, etc. I just needed to know the recommended size, looks like it will be 2½".
Thanks again,
Mike
Old 06-26-2009, 08:32 PM
Hard Core Z28's Avatar
Dual 2.5" will be a good choice.
Old 06-26-2009, 09:48 PM
Lopoetve's Avatar
what do most exhaust shops expect to use? I'm guessing if they want back pressure, they try to push 2" or the like?
Old 06-26-2009, 11:58 PM
KurtRardin's Avatar
No, not quite that low, but they'll start rambling about how dual 3" pipe will make it loose power, burn more fuel, burn valves... and that an x pipe's job is to add back pressure and does not change exhaust tone... and that mandrel bent pipes don't flow any better than crush bent pipes.
I bought a welder and swear never to go to another shop that thinks my 5.7 liter is a 350.
Old 06-27-2009, 02:16 AM
Lopoetve's Avatar
ah, gotcha. I'll remember that
Old 06-27-2009, 01:32 PM
01ssreda4's Avatar
i agree, i would personally go with whatever size my header collector was or 3 inch whichever was bigger....
Old 06-27-2009, 03:37 PM
thunderstruck507's Avatar
I have 2.25" on mine and as of now with this tune I don't make any more power with cutouts open than closed. Cutouts are a foot or less behind the headers, exhaust goes all the way to the back.
But if I were running a new system I would go 2.5" just to be safe and maybe be a little louder.
Old 06-27-2009, 04:59 PM
sciff5's Avatar
This is the biggest pile of horseshit I've ever heard. Dual 3" will if anything help it wont hurt.
I run true dual 3" all the way back and I had some of the best numbers for a bolt on ls1 at my local tuner, and then turned some of the fastest times ever run by a bolt on ls1 rx7
To the original poster, keep it simple and run exhaust the size of the collectors on your headers, which are probably 2.5". I think X pipe really makes the car sound better, but thats more opinion than anything else
Old 06-27-2009, 06:07 PM
KurtRardin's Avatar
That's the point that I was trying to make too, but most exhaust shops will try to tell you otherwise. You should have seen the looks when I proposed the idea of a 4" merge collector on my Y pipe... they thought I was crazy. Well, a cam, 4.10s, and a 4" y pipe later and I still get 28mpg on the highway.
Old 07-01-2009, 03:07 PM
Daez's Avatar
Dual 3" here.
Old 01-14-2021, 06:15 PM
off2fly's Avatar
Anyone got a recommendation on mufflers ? I have 5.3 stage 3 cam, and nice heads, I’m running 2.5”pipes but very little space under this 35 Chevy coupe 😬, need to eliminate droning if possible... Thanks, Vann
Old 01-14-2021, 09:58 PM
Received 3,024 Likes on 2,355 Posts
Magnaflow.
The following users liked this post:
oldngray (02-26-2021)
Old 01-15-2021, 07:11 AM
showdog75's Avatar
I'm a Borla fan. When it comes to sound I like quality over quantity.
Old 01-15-2021, 03:03 PM
off2fly's Avatar
Everyone been telling me that Borla is too Loud, Thanks, Vann
Old 01-15-2021, 06:09 PM
I think a lot depends on the size of muffler you get from your brand of choice. Both Magnaflow and Borla make different length (and sound level) of mufflers.
Old 02-18-2021, 07:55 AM
tberg725's Avatar
I can only nod my head yep to what’s being said here lol I had 3 of my buddys PREACH for WEEKS saying the headers I put on my car were “too big” and would kill back pressure and burry my torque because I went with 1 7/8 primary’s to 3in collector with 3” dumped x-pipe just blew them off well long story short after the awesome results I had my buddy ditched his 1 5/8 / 2.5in collector headers and got nice gains on the dyno......
these were also the same people who nagged me to death when I ordered my 4,000 stall converter saying it would make my car slower than stock lmao
Quick Reply: Exhaust pipe size w/LS1 in a street rod??
