Found my oil leak, need help diagnosing.
While installing my LS6 intake manifold, I took this picture:
To compare, here is what the top of the block should look like:
With the manifold back on, you can see where the oil leak has been:
This rubber elbow circled in red has a cut in the bottom of it, which was caused from a metal strap of some sort that goes inside the tube. I'm guessing that this is the PCV system?
I had the same issue on mine. Except it was the the fitting in the back. It was a boot that had two hoses meet to come out to one. GM wanted $120.00 but the complete set. They said they couldn't get just the boot. I made my own with heater hose and a Brass T fitting. Its been holding up great and costed me under $10.00.
Take all your stuff off and just recreate it with new heater hose and fittings. Its all at the auto parts store.
this guy might have a nice used one pretty cheap:
parts@tacreationsusa.com
