Wiring Question
Wiring Question
I bought a Nitrous Outlet 78mm plate set up and looking at all the different wiring scematics and was wondering if it was best to have your bottle heater with pressure switch and remote opener on different relays. (For a total of 3 relays)
I have to say that the Nitrous outlet directions that come with the kit are quite lacking. It doesn't say one thing about the digital dual window switch and what wire is what. All of my guidance has come from your sticky on Nitrous Wiring.
I'm not bashing them, maybe they gave me the wrong instructions but the instructions I received are for a basic wet set up and I know it doesn't take a genuis to figure out that instead of hooking up to a jet in front of the TB and just hook up to the plate but it would have been nice, since I bought it as a package to have a schematic to hook up everything in the package.
Guest
Posts: n/a
The system intructions are for use with a system only and they dont have any provisions in there for use with a window switch, FPSS, remote opener, or bottle heater < Not everyone buys the accessory items when they buy a kit >. The window switch should have come with intructions and a diagram in the intructions....the same with the heater and remote opener.
IF you want some specific diagrams I have a couple i can send you.
Let me know if you any help or anything
-Chris
-Chris
-Chris
-Chris
You can email them to me if it's easier. brnagain @ maine.rr.com
LS1TECH Sponsor
The pressure switch activates the relay for the bottle heater so they dont need separate relays. Also our opener does not require a relay either. The opener requires roughly 3.55 amps @ 12.8V.
