Drag Racing Tech
How much gain from a little weight loss?
Old 06-27-2009, 05:31 AM
taws6's Avatar
Default How much gain from a little weight loss?
Hi,
I am considering removing the spare & jack, rear seats & belts, rear floor mats, and hatch cover (approx 70).
What sort of time will that knock off, and that = how much gain rwhp?
Thanks for the help......
Old 06-27-2009, 06:30 AM
Dirty Dog's Avatar
Rule of thumb is 100lbs = .1 sec.
Old 06-27-2009, 06:42 AM
keith_AE2010's Avatar
This is true. Although, just because you are going faster, you are not always gaining rwhp. You are just making your car less to move, and therefore faster.
Old 06-27-2009, 09:03 AM
2nd Gen Fl 'bird's Avatar
So wrangling over an ls1 or iron block isn't worth the lost sleep? 6.0's are cheaper.
Old 06-27-2009, 09:12 AM
TJ
TJ's Avatar
depends on your intentions of the car.
i wish i had that aluminum block. 6.0 aluminum.
Old 06-27-2009, 10:04 AM
ndfrsd6's Avatar
im so glad i went with my LS2 block over the iron ......every pound helps
Old 06-27-2009, 10:14 AM
3.8redbird's Avatar
Inertia and friction variant it all you change
no more power is right
Old 06-27-2009, 03:57 PM
taws6's Avatar
Okay thanks.
Not sure the reduction is worth the loss of the seats, may just lose the jack & spare.
Thanks for the help
Old 06-27-2009, 04:01 PM
scrapmetal's Avatar
Originally Posted by taws6
Okay thanks.
Thanks for the help
Just don't get a flat!
Old 06-27-2009, 04:20 PM
landonew's Avatar
I think any reduction is pretty much a waste of time unless you plan on taking 200-300+ lbs out of the car. Don't lose your jack and spare tire if that is all you plan to take out.
Just take it out at the track, that is sufficient.
Old 06-27-2009, 05:07 PM
taws6's Avatar
You're probably right.
Old 06-28-2009, 08:18 AM
I agree 100%.
Old 06-28-2009, 01:40 PM
mike c.'s Avatar
I gained 1.5 tenths when I removed the entire air conditioner system and front sway bar. all togeather it was 47lbs off the nose. funny thing when I added a tubular front end back to back I didn't gain from that.
Old 06-28-2009, 04:22 PM
6techniques's Avatar
very true....if youre gonna go, it might as well be worth something.
Old 06-28-2009, 10:14 PM
CamaroRacing12's Avatar
i take out every bit i can. to me every ounce helps
