Over heating with a verticle griffin. Anyone else??
Old 06-28-2009, 09:54 PM
phildo's Avatar
Default Over heating with a verticle griffin. Anyone else??
Have a turbo really close to the radiator and my 4"dp runs along side the motor. I have a 16" fan on the same griffin everyone runs on here and am having temp issues. Runs around 200* when 70* out but seems to even struggle there. Slowly creeps up to 210* when beating on it. When it is 80* out my car runs 210* and creeps from there. If I get stuck in traffic I will overheat for sure.
Anyone else having issues? Any suggestions? I am thinking about having all my pipes ceramic coated in and out. They are wrapped right now and I am wondering how much of a temp drop I might see? This just takes all the fun out of driving it.
Old 06-28-2009, 10:48 PM
black98ws6ta's Avatar
Is the fan you have now shrouded? I would put a nice set of dual fans on the car.
Old 06-28-2009, 11:17 PM
conan's Avatar
What temp T-stat are you running?
Old 06-28-2009, 11:26 PM
phildo's Avatar
Fan is unshrouded. Not ideal for surface area but have space issues. The Stat
is a 195. I'm just wondering if I have a problem like air in the system. Once the temp starts to climb I can't get it to come back down even while moving. Just holds that temp till I stop then climbs higher.
Old 06-28-2009, 11:38 PM
conan's Avatar
Might have some air in the system, and may want to get a 160 stat.
Old 06-29-2009, 08:09 AM
Fireball's Avatar
pusher or puller fan?
Old 06-29-2009, 02:37 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I ran a pusher and a puller. Temps would creep up to 210F and stay there after I beat on it on the street.
Old 06-29-2009, 10:42 PM
phildo's Avatar
Fan is a puller. Gonna mount a pushed this weekend. I think I found the problem. I put the head steam hose in the upper radiator hose and it is higher than the radiator. I need to figure out a way to bleed the air out. The middle of the upper hose is probably all air. I'll let you guys know if it works. Thanks for the help
Old 07-14-2009, 08:52 PM
phildo's Avatar
I am at a loss. Added a pusher fan,a bleeder on the t-stat housing, and bled the upper hose. The car seems worse than ever. The temp will not stay at any temp for more than a minute or two. Climbs one degree at a time till I hit 230* Car over heats after 30mins of driving. The car had no issue until I used the verticle radiator,change my turbo set up, put the steam hose in the upper hose, and redesigned the t-stat housing.
It is either the stat housing design or just too much damn heat under the hood. Could I have such bad angles on this lower hose that it messes flow up? I have a straight t-stat housing cut at a 45* and a pipe cut at a 45* so the flow comes out of the housing straight down and angled back toward the motor. It is a terrible angle but I figure as long as the diameter is the same it would flow fine. Right? Is there something I don't know here?
Old 07-14-2009, 09:00 PM
Do you still have the lower air dam that directs air up? What about all the factory plastics that force the air towards the radiator? Can you fit the dual slim line fans as pushers? If the turbo is close, maybe a blanket for it?
If you just start the car up from being cold will it keep the car cool at idle? What about if you drive it awhile and then park it at idle does it cool back down? I have never had any luck with unshrouded fans.
Old 07-14-2009, 09:05 PM
LS1Tech Co-Founder
Onfire would ask, does it overheat while moving or standing still? That the first question Master Luke.
Old 09-17-2009, 09:20 PM
phildo's Avatar
Well it over heats idling and moving. I just redone the thermostat housing and lower hose with no change. Has anyone had problems with aftermarket housings/thermostats? I am going to try a different stat also this weekend for the hell of it. Has anyone had a water pump stop flowing? Somtimes it seem ok and then it will start climbing slowly until it gets into the 230's. I just can't believe this radiator is struggling to cool this setup while moving!?!
Stat is a 180*. The lower air dam is on the car. The upper plastic that directs air to the radiator is off.( not for long)
Old 09-17-2009, 10:20 PM
firefightergib's Avatar
not sure cause im running the same radiator with the PTK kit, and the turbo is only 3 in. from the radiator and Ive yet to have to turn the fans on, it never gets above 200 even in traffic and ive drove it in 90degree weather, im kinda leaning toward possibly air in the system
Old 09-17-2009, 10:33 PM
otherwhitemeat's Avatar
Originally Posted by phildo
Well it over heats idling and moving. I just redone the thermostat housing and lower hose with no change. Has anyone had problems with aftermarket housings/thermostats? I am going to try a different stat also this weekend for the hell of it. Has anyone had a water pump stop flowing? Somtimes it seem ok and then it will start climbing slowly until it gets into the 230's. I just can't believe this radiator is struggling to cool this setup while moving.
Sounds like a blown head gasket
Old 09-17-2009, 10:53 PM
phildo's Avatar
Was perfect with my old turbo setup. This didn't start until I Made a new t6 setup with the verticle radiator. I have put 12psi at it with this setup and it runs great. I know it's not the head gasket.
Old 09-19-2009, 03:20 PM
cjg454ss's Avatar
my setup would always run hot until i got the stock fans back on a large griffin.
Old 09-20-2009, 12:24 AM
98Camarod's Avatar
Mine overheated until I put the Taurus fan on it. If it is overheating or if the temps aren't decreasing while you are moving also then your cooling system isn't doing it's job, ie bad waterpump, clogged coolant passage, air in the system
Quick Reply: Over heating with a verticle griffin. Anyone else??
