Cadillac CTS-V - Magnavolt Functions
View Full Version : Magnavolt Functions
TexVette
07-12-2009, 12:59 PM
Does it strictly increase voltage to the fuel pump, or does it affect timing/fueling in any way at all? I'm pretty sure I know the answer but I need to make sure. Considering removing it from my setup and using a walboro instead.
If the magnavolt works the way I think it does I'm pretty sure I can remove it and install a walboro without any retuning.
SkullV
07-12-2009, 01:20 PM
Just boost fuel pump voltage, I'm not sure how it does it, but it has nothing to do with PCM functions. A Walboro or Racetronix in tank pump would take its place nicely and be more reliable.
CTSV_510
07-12-2009, 01:38 PM
What Ted said is right. It is triggered by boost and I believe it kicks in at 3 or 4 psi.
rand49er
07-12-2009, 09:31 PM
I just bought one, so this is good know. :D
Justin311
07-14-2009, 12:50 PM
How much is a Walboro or Racetronix pump? Is that a better route?
DoctorNick
07-14-2009, 03:15 PM
I hear dropping a new pump in the tank is kinda a PITA, but its the route I would feel best taking.
onebadcad
07-14-2009, 05:21 PM
Jamie, my tech, decided that after taking 2+hours on a lift to drain the tank (and getting covered in gas) and replace the pump, that the next time it shiats out, the Aeromotive will be going on my car.
DoctorNick
07-14-2009, 09:07 PM
OBC, what did you have Jamie put in the tank?
TexVette
07-15-2009, 12:26 PM
I'm not even sure where you can buy the racetronix setup for the cts-v. I was lucky enough to encounter a forum member in my city who had a kit, but sold his caddy. Talk about luck.:nod:
Putting a higher volume pump in the tank is a better way to go than overdriving a stock pump in my opinion. My plan is to put the walboro in, then when I have the need I plan on replacing the magnavolt unit to overdrive that pump as well. Of course, that would only be if I'm looking for over 600rwhp. Really the only thing that matters is that you're getting ~60psi ALL the time at all rpms with as little drop in pressue as possible. However you accomplish this is up to you.
I bypassed the magnavolt for the time being by jumping the yellow and grey wires. Another way to do this is to access the wires in the passenger side trunk panel. I went in there and re-wired the connections because they only had a screw on connector whick I don't particularly like. Now they've got heatshrink butt-ends on em.
Magnuson tech support was really good. Spoke to Drew two times and I appreciate the time he took to answer my questions.
I plan to drop in the pump sometime this weekend. It's so freaking hot here in TX right now I'm going to have to wake up at 6 am and get to it before it hits 100+ I'm in a garage but that's still too hot. Will post write-up when it's done. I doubt it will be that hard.
onebadcad
07-15-2009, 12:41 PM
Cannot remember, I think Mike or Johan at DiabloSport ordered it when I had a fuel deficiency after I put the stroker in---I could guess, but that would be of no help. I realize there are much better pumps than the stock one, but think that based on the PITA factor of going into the tank, an external one is better. Then again, how loud is an external pump, may be irrelevent, as the headers, exhaust and whine of the Maggie will be louder.
