Narrowed LCA Bracket
Anyone ever see an advantage to a narrowed LCA bracket on rear end side? Seems to me you would run into problems with the control arm rubbing front of tire before you have problems with the bracket on the rear.
If you did have a narrowed bracket, who, if anyone, makes a control arm that has a narrowed mounting point on the rear end side to fit into the bracket?
