Header Panic
Old 07-17-2009, 02:02 PM
Zaxz28's Avatar
Default Header Panic
I am in frustration mode, I just finished bolting up my edelbrock shorties, and a started it up and it pulsated for a while then stalled out... with an ses light blinking. what looked like exhaust started bellowing from the engine after it stopped looked around and the cats needed a little tightening up, I am waiting for it to cool down a little before I tighten them back up....How tight do I tighten the catalytic converter to the exhaust header? Do I really wrench it down? Can I clear the code myself by unplugging the battery, how long do I have to wait? what can I do it it continues to leak. Please somebody help...
Zach
Old 07-17-2009, 02:20 PM
burnout346's Avatar
Did you reconnect the o2 sensors?
Old 07-17-2009, 02:26 PM
Zaxz28's Avatar
yep all reconnected, would a spark plug wire not hooked up well cause it?
Old 07-17-2009, 02:32 PM
burnout346's Avatar
What year model and did it stay running or die?
Old 07-17-2009, 02:35 PM
Zaxz28's Avatar
2000 z28 stayed after unplugging and leaving it, it will stay until I give it a little throttle, then it will die. then on second start it stays running.
Old 07-17-2009, 02:37 PM
burnout346's Avatar
Are you still running AIR & EGR? Did you swap the headers with the spark plugs still in?
Old 07-17-2009, 02:42 PM
Zaxz28's Avatar
Still running all emissions all hooked up, just tightened up cats don't see anymore exhaust leak, but still have ses light..... Found a loose spark plug wire on the back passanger side. I kept all spark plugs in.
Old 07-17-2009, 02:43 PM
Zaxz28's Avatar
Found sparkplug wire after I already plugged in the battery.
Old 07-17-2009, 02:44 PM
goldmecham's Avatar
might have cracked a plug when you installed the headers. i always put new in its cheap. get some ngk tr-55's
Old 07-17-2009, 03:01 PM
burnout346's Avatar
I agree. Change your plugs and see if that works, if not let us know.
Old 07-17-2009, 03:53 PM
Zaxz28's Avatar
So I limped it down to an autozone about two miles away....misfire on cylinder 6!!!! he touched it and it fell off, son of a b__tch.... I am an idiot, he said that was the only code he saw so I am reseting the computer now...
Old 07-17-2009, 04:36 PM
Zaxz28's Avatar
straightened it all up no ses light after reset, what should I look for in the next couple of days, problems wise...
Old 07-17-2009, 04:48 PM
burnout346's Avatar
Bald tires! you should be good to go. Just retorque the headers after a few heat cycles.
