Wiggly Clutch Slave
Wiggly Clutch Slave
I was having some clutch problems with my 02 M6, I have recently replaced the slave so I figured it was the master...and when I went to unhook the master line from the slave I noticed the part that comes out of the slave was really....well wiggly...I could move it around easily about 1/4 to a half inch..I don't remember it being like this before I replaced it but cannot remember.
I threw away the old slave so I have no comparisons...I'm thinking the two bolts holding the slave on are loose and this is why I can wiggle the connector going to the slave easily...I torqued them down to spec when I installed..Guess I should have used some loctite on those bitches.
Clues? Is the connector supposed to be loose like that?
I realize everyone is really busy with "what clutch is best" threads, but if someone has a second it would really cheer me up to know if my car is done for the season or not.
well, there is only a spring pin that holds the slave line into the slave....it SHOULD wiggle a bit, nothing to worry about tho...there is no real "almost out" if the line viberated out it would be sudden...and on the ground, no getting loose. GOOD LUCK
I'm more worried about the two screws keeping my clutch slave from coming out being loose. But it's hard to tell with the whole thing together, I just had the trans out a month ago and am pretty ******* sick of clutch issues and rear main leaks and all the ******* bull **** that comes with this car. In fact, you know what the son of a bitch is for sale 41k 02 WS6 Come and ******* get it I'm done with the ****** 15k obo, posting it in the ******* for sale section right ******* now.
