exhaust clamps
exhaust clamps
Are these good? http://www.summitracing.com/search/D...t/?Ns=Rank|Ascdo you guys recomend something else. I have the crappy U bolt clamps on my Magnaflow right now and want to swap them out.
The walker clamp you show and the accuseal clamps are the two best clamps on the market (I believe). They have different uses but those two will do the the job in most cases.
http://www.stainlessworks.net/cart/i...ath=95_367_141
You could just weld the pipes up, the ditch the clamps all together.
Or you could put 2-4 spot welds on each pipe connection, then also use the single bolt band clamps.
I found that the larger 2 bolt band band clamps work best for a daily driver, otherwise moisture has a tendency to rust the pipes under the clamps.
