slow power windows...
I guess this is a common thing with these cars, and I seem to rember someone saying the passenger side is underpowered somehow, anyone know where I read that?
And is there a way to speed these up?
I also wonder is it normal when you roll the window down, the door liner pushes into the car some, from the last couple of inches going all the way down??
Thanks for the insight
BCM = body control module?
A new motor sounds good.
Is it a direct swap for a more powerful motor?
It sounds like the rivets need drilling out and the motor replaced with the new one?
I guess the rivts are all hiden behind the pannel?
Thanks for the help
Thanks for the help
Yes, everthing you heard is true. I'm too lazy to do a search for you but the pass window has a wire problem that reduces the available current. There is a fix out there for that.
Also the panel moved from day one with mine.
It is too bad the first LS1.com forum lost 5 years of posts from all us original owners. There was a great source of info in there.
LS1UNIVERSITY may have something.
Good luck.
Good luck.
actually http://www.autotrix.net has a kit still as well as other usefull things such as one touch express passenger kit. It's freaking expensive though.
