Gears & Axles - who makes the strongest and lightest rear?
blackls1ta00
07-29-2009, 07:25 AM
im looking for a tough rearend but would like to be on the lighter side to keep weight down.
Intercooler2
07-29-2009, 07:40 AM
I had the same thoughts as you but that extra weight is in the right place from what I have seen so far... right on the rear wheels at the back.
Fabbed rears should be the lightest
LS1crazy01
07-29-2009, 07:43 AM
Talk to Eric at Midwest Chassis and performance. He could set up a Fab 9" that wieghts less then a 10 bolt. My set up is only 12lbs heavier then my factory 10 bolt. 31 Spline axles,4.11's,posi,powder coated,4 channel, the whole works. Also Eric's work and his crew are spectacular at what they do. And his customer service is just as increddible as his rear ends are.
blackls1ta00
07-29-2009, 07:46 AM
is it worth it to spend 3500 on a rear though?
blackls1ta00
07-29-2009, 07:48 AM
ill give him a call thanks
Intercooler2
07-29-2009, 08:27 AM
$3500? I didn't spend near that for my MWC unit. I think I had $2500 in the entire setup with everything added.
blackls1ta00
07-29-2009, 08:49 AM
base price is starting at $2700
Intercooler2
07-29-2009, 08:59 AM
Yup and that is a complete with center section and assembled. Just bolt it in! I ordered housing/axles and got my own center section. We ended up assembling it. If you buy the base you just swap them... 3 hours tops. For us it took about 7 hours so getting one complete for $2700 may not be so bad.
blackls1ta00
07-29-2009, 09:12 AM
yeah,im waiting for mwc to call back,im prob gonna need a spool or locker with 625rwhp.now to decide on which gearset 410 or 430 for use with 28 in tire and nitrous...
LS1crazy01
07-29-2009, 10:01 AM
4.10 will be plenty if you got that kind of power and especialy spray.
LS1crazy01
07-29-2009, 10:04 AM
Yes it is, and if you want a super light setup it will take drilled 33 spline axles and either a locker or spool. I paid under $3,000.00 installed for mine. If you add everything up against any other rearend out there he has the best bang for the buck.
SSdreamz
07-29-2009, 01:04 PM
so which is it? 2500 or 3500 for everything?
blackls1ta00
07-29-2009, 04:04 PM
talked to eric and he said 3600 shipped for a fab 9 spool w 410s gundrilled lightweight axels,lightweight center section,with powdercoating and new crom moly ds,sounds good to me,also weight will be 10-15 pounds lighter than 10 bolt.im gonna order in few weeks,thanks for help guys.
LS1crazy01
07-29-2009, 05:44 PM
No prob, let us know when you get it in!
Sprayed 99
07-29-2009, 06:18 PM
just make sure u go with 33 spline or bigger if u didn't know already. i've seen a couple cars twist or break 31 spline axles with similar set ups to yours.
SHovV
07-29-2009, 07:21 PM
625 to the wheels, on motor or nitrous?
blackls1ta00
07-29-2009, 07:46 PM
on nitrous 150 shot
blackls1ta00
07-29-2009, 07:48 PM
i think he said 33 or 35s i should be set.
Chris05ssTruck
08-01-2009, 07:53 AM
U won't regret it; love mine. Hardley any noise.
03 BUSA
08-01-2009, 07:55 PM
Another vote for Midwest. Eric is the man.
studderin
08-01-2009, 08:37 PM
I looked into getting a "lighter then 10bolt" fab. 9 setup. It was up to $3450+ so for now my $ 2,100 S60 will stay. It wasn't worth it to me I could get a lot of power for that money and go faster then what saving 40-50 pounds would really do.
bowman2005
08-02-2009, 02:50 PM
So will this fab 9'' be just as strong or stronger than a moser 9"? How much heavier is the moser 9" over the stock 10 bolt?
Chris05ssTruck
08-02-2009, 05:09 PM
Moser units have been known to be noisy as hell, gear whine, tq. arm noise.
To many bad stories for me.
Fab 9's are about as strong as u can get for a 9'.
ItsNotStock
08-02-2009, 05:21 PM
Fab 9's are as light as a 10 bolt, but as strong as a nine inch. You pay for what you get with rear-ends.
The Moser M9 is one strong rear, which is in my car shown below. Bob
Here is a link to my pricing on the M9. http://www.exoticperformanceplus.com/performance_parts/index.html?item=1324
Video: http://www.exoticperformanceplus.com/performance_parts/index.html?item=1355
http://www.exoticperformanceplus.com/performance_parts/index.html?item=1469
http://i226.photobucket.com/albums/dd185/EPP_photo/Muncie14.jpg
chrs1313
08-15-2009, 01:22 AM
my 12 bolt with drag brakes was around $2800, and was 25lbs lighter than stock 10 bolt with calipers & rotors...so probably around the same weight minus the brakes
TNTramair
08-15-2009, 12:46 PM
the $3500 that Eric charges is also including the driveshaft and the bran new Torque Arm which isnt included with a Moser or any other rear you might get. if you price everything out, it'll end up costing about the same as, if not a little more, than a MWC rear. i paid $34xx for mine and it came complete, ready to install. 4 channel etc. with a strange center section but it was quite heavier than my 10bolt as we noticed from tryin to pick it up into the car but its been rock solid and quiet as can be. worth every penny for me thus far.
