Blueprints for mountings
I’m going to install an ls1 engine in my El Camino -69 and now I'm looking in different ways to mount the engine in the frame.
I have looked around in this forum many times and in a lot of threads I have found people who are referring to some blueprints for engine mountings. The mountings are for fitting an ls1 engine in an a-body. From what I’ve understand the mountings will look similar to the brp’s ones.
I hope you can help me finding the blueprints. Thanks.
There are two basic designed (and so called names), BRP (Early design) and the S&P/ATS (standard and 1" setback and this design is marketed by many vendors; Hooker, Edelbrock, Carshop, etc ).
Both Templates are in the FAQ and can be used to fab up some adapter plates from Steel or Alum. (1/4" to 1/2" thick). They both will generally work on any older (and newer) cars that are setup for a SBC Chevy. With some minor mods they will work with any car if you can use some SBC or fab'd up Engine Frame stands.
