Ran the V tonight (bone stock)
I met up with a few guys from ls1tech. There were 3 V's total tonight. Not much going on at the track so we pretty much ran at will. I'm sure they will post their times as well.
Given the crappy weather conditions tonight (upper 80's and just shy of 90% humidity) I think it did well. We were all drenched in sweat just from standing around..it was quite miserable. I made 4 passes spaced anywhere from 30 minutes to an hour apart each time.
Run 1 was trac control on. I figured I could just launch it hard and trac control would be smart...well it still spun and wheel hopped..blah. 2.3 60' 13.8@105
rest of the runs were trac control off in competition mode:
Run 2: 2.2 60' (spun, no wheelhop though) 13.7@105
Run 3: 2.1 60' (no spin, launch @ 4k rpm feathering the clutch) 13.66@105
Run 4: 2.2 60' (same launch as last time but feathered too much) 13.70@102
As the humidity got worse, the mph got worse..lol. Run 3 and 4 both could have been kickass if I had put a little more power to the ground. Overall I'm happy espically since there were 12.5 sec cars running low 13's because of the weather. I can't wait to run it when the weather gets better in October or November.
Launching the car safely was a lot easier than I thought. I just keep the rpms up and work the clutch. I'm pretty sure with a few more passes I could have broken into the 2.0 range with no wheelhop or spin.
EDIT: also all the runs were granny shifting 1-2 and power shifting the rest...after the 1-2 shift, the foot never left the floor
my best was a 13.83 @ 108 I need the driver mod bad first time to the track wasnt too hard to launch with out wheel hop but hard as hell not to spin like crazy from second to third made 5 passes
funny thing was going there I was running with my friend in a 08 c63 amg with tune and we were side by side did some 50 to 120 runs did one to 150 he jumped that one but I held my ground yeah right he ran 12.5x and 12.6x constant but he has an auto
Yea it did seem like u were having a bit of trouble. Didnt get a chance to talk to u like I did the others, but friends and I thought u could've used a bag of ice between runs to cool that maggie down. Nobody there was running what they were supposed to. The track could've been prepped better and it was just way to muggy.
A few friends were calling it "slippery madness" because they were spinning 2nd and 3rd when usually they only spin 1st and only a portion of 2nd. It's usually only good to go on test N tune.
master of the "jack"stand
Sorry, just a meteorologist busting your ***** here.
Also jealous of your V.
Upper 80s and 90% humidity do not happen in Louisiana or hardly anywhere else on earth. A mid 70's dewpoint (common for your area this time of year) would have given you a humidity in the low 60% range.
EDIT: I just checked the weather right now at 8am...its 78 degrees and 88% humidity and sunny. It sucks here. That kind of humidity happens all the time. I've been racing for years down here and always checking the weather before every run
Nice runs by the way.
Watch the humidity drop as the temp goes up. By the time you reach the upper 80s the humidity oughta be down in the 60% range. If you had upper 80s and 90% humidity believe me you would barely be able to breathe because that would be like an 87 dewpoint.
right now in tampa its 90* 75% humidity and freaking miserable. Tonight is forcasted to be in the mid to high 80's with 88% humidity per weather.com
