greg welds
Old 08-02-2009, 08:12 PM
TravisMcGill2000's Avatar
Default greg welds
i came across a good buy in a set. There on a 03 cobra now but he said they will fit a trans am to. they are 15x3.5 and 15x8s with 5.5 backspacing... The ? is will they fit my lt1 trans am. I know i will have to do some grinding and run spacers. But will i have any problems with these
Old 08-02-2009, 08:19 PM
great421's Avatar
Ford stud spacing (4.50") is not the same as GM stud spacing (4.75") - unless they are set up with BOTH sets of holes (10 holes per wheel) or with slotted spacers for studs (which flip-flop), these will NOT fit.
Old 08-02-2009, 08:32 PM
i know they dont have 10 holes but wats the slotted spacers look like. the bolt holes look slotted
Old 08-02-2009, 09:36 PM
DopdBrd's Avatar
You just need to buy the right lugs and washers. They aren't slotted though which is weird, I think us GM guys got lucky and just any regular shank nut and washer will work. At least that is what I used on them.
They are made to fit both 5x4.5 and 5x4.75 bolt patterns.
Old 08-04-2009, 12:32 AM
litemup02's Avatar
Yeah here are some pics another member posted that shows the offset washers. Mine are the regular ones too.
Old 08-04-2009, 09:30 AM
Camaro396's Avatar
Everyone knows Greg Welds fit both GM/Ford/Mopar bolt patterns.
The fronts will bolt right on with no issues.
The rears will not fit without a SERIOUS unsafe amount of grinding. I think only one or two people ever ground enough to fit the rears.
To keep a good looking budget setup, most people just run Weld Prostars in the rear, to keep the grinding minimal. Here's my old setup with Greg Weld fronts and Prostar rears.
