TA diff cover
well, not much to learn about a rearend cover. it holds in the fluid and helps to keep the rear together since the 10 bolts arent great under power. outside bolts go to 20-22 ft lbs, and the center 2 bolts torque to 6 in lbs.
One thing that bugs me is the TA cover doesn't have a magnet, but the stock one does. I've been thinking about rigging one in there. Supposedly slightly higher fluid capacity with the TA cover also.
