How much boost for a stock engine
Old 08-05-2009, 12:49 PM
UrSmked's Avatar
Default How much boost for a stock engine
I have a '00 Trans Am and I am making 6 lbs of boost now on a basically stock block. Racetronix Fuel pump with hotwire kit, 42 lb. Injectors, Vortech supercharger with aftercooler, full exhaust, fast intake. The rest of the fuel system is stock and right now I am making about 470 rwhp. If I wanted to change out the pulley to a 2 3/4" that would put me up around 8 lbs. of boost. Is that too much on my motor?
Old 08-05-2009, 02:17 PM
conan's Avatar
Only one way to find out, put it on and see what happens. Here's some reading materal... https://ls1tech.com/forums/forced-in...lity-list.html
Old 08-05-2009, 02:20 PM
IT_SS's Avatar
Old 08-05-2009, 07:52 PM
MY99TAWS6's Avatar
Generally 5 to 7 is a nice psi for most FI setups. Buddy pushed his ati car to 8..kaboom on the stock ringlands. Only had it up there briefly.
Its playing with fire to run much boost on the stock hypercrap pistoned motor.
Old 08-05-2009, 09:00 PM
gametech's Avatar
8#'s requires the same safe tune that 6#'s requires. At those levels, it isn't the boost that blows the motor, it's the tune. I have seen stock bottom ends accidentally overboosted (for a few seconds) to almost 20psi without any damage. They obviously wouldn't have handled this for very long, but it says a lot for what the parts can handle as long as detonation doesn't hammer them.
Old 08-05-2009, 11:09 PM
dudeman's Avatar
mine let go at 12psi. my 108k stock bottom end didnt like the boost!!!
Old 08-06-2009, 01:16 AM
tomz28's Avatar
im running 12 to 13 right now
Old 08-07-2009, 07:16 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
9 pounds of boost on a stock engine with a conservative tune will give you a reliable set up. Anything more aggressive and you start living on borrowed time.
Old 08-07-2009, 10:35 AM
baylove's Avatar
+1
Old 08-07-2009, 01:26 PM
blue00ZZleeper's Avatar
+ another 1 ...i'm hoping mine holds at 12 soon lol
Old 08-07-2009, 01:42 PM
crf538's Avatar
define "let go" haha, was it a piston or a rod? im running 12 psi now but my tune is pretty conservative
thanks
Quick Reply: How much boost for a stock engine
