90MM HSW Plate Max wet shot?
Well i had a HSW 90 dry kit that i was spraying 150 dry. but now i upgrade the solenoid and added a fuel one also. But my question is; whats the max i can spray thru the plate and what jets should i use? i want to do a 175 or maybe even a 200 shot( i checked the sticky and tryed the formula, but im not too sure if its correct).... or is the the max 150 and cant do any higher? thanks guys
