shift through nitrous?
set it before the car shifts, at like 6200 or something?
Or stop being a puss and shift with the nitrous on?
Robert
You mentioned your tranny is built, so you should at least put the window at the shift point. That way, if your 2-3 shift decides to R.I.P, the nitrous will cut off in time before it bangs the rev limiter. Thus, saving your motor..
If you want to be safe then set it to come on at 2800 and off at 6200.
unless you figure out what the car drops to and figure a way to set it up like that there is no way to keep the spray off threw a compleat shift.
dont be a puss. spray it. like i sad you cant stop it so why waist the 200-300 rpm of off time.
i would however be sure to set it just befor your limmiter. so in your case kill it at 6600 so if you slip it you wont be hitting the limiter with spray on
good luck
Robert
Robert
