throttle sticking after spray
Old 08-10-2009, 09:43 AM
6point7s14's Avatar
Default throttle sticking after spray
Its done it a couple times on the dyno and after a track pass. I have a HSW wet kit thru a nozzle mounted about 6 inch from a nick Williams 90mm throttle body. It doesn't stick on motor. But it does on spray. Any suggestions?
Old 08-10-2009, 10:03 AM
Moderator
jimmyblue's Avatar
Icing maybe? Does the aftermarket TB have a coolant
passage?
Old 08-10-2009, 10:52 AM
6point7s14's Avatar
passage?
I believe it doesn't buy I may be wrong
