Starting my Turbo build
Old 08-18-2009, 04:57 PM
americanexpress's Avatar
Default Starting my Turbo build
I am looking to add a turbocharger to my 01 WS6 M6. Did a lot of searching in the forced induction threads before deciding to make an account on this forum. was looking at some of the kits you guy have on your cars. I want a front mount style single. keep ac and run stock everything(maybe clutch upgrade.) I like the
http://www.fast-track-performance.ne...products_id=90 kit because its complete. havent found any info on this kit on the site. just wondering if you guys have any info. Looked at the KY turbo setup(very similar). i want a complete kit. also any info on running the car on e85 would be great.
Old 08-18-2009, 04:59 PM
Pat-Man's Avatar
You staying stock cubes? I would highly recommend the TTi street kit if you are. I'm currently running that kit on my Camaro w/ the T76.
http://www.turbotechnologyinc.com/site/?page_id=113
Old 08-18-2009, 05:20 PM
i am currently staying with the stock block, until it coughs something out the block. I want a kit that i can eventually push upwards of 800+whp on built motor.from what i read the truck manifold kit can do that easily. tti is kinda limited isnt it? how much power does the stock clutch hold?
Old 08-18-2009, 05:30 PM
99Z28LS1's Avatar
The "kits" usually aren't the limit... It's usually the turbocharger itself, intercooler, fuel, shortblock and other miscellaneous parts that will give out with added power
Old 08-18-2009, 05:38 PM
thanks guys keep the info coming.
Old 08-18-2009, 05:39 PM
frcefed98's Avatar
Go with Josh@KYTP he makes great kits and has one to fit your needs.
J
Old 08-19-2009, 02:57 PM
come on guys
Old 08-19-2009, 06:12 PM
dudeman's Avatar
with the truck manifolds you cant keep ac. as far as the clutch, your gonna need a good one. my centerforce wasnt up to the task on 12lbs of boost!
Old 08-19-2009, 08:13 PM
the fast track perfomance kit will keep the a/c. i talked to a guy who has one and the guy who builds em. its based off the c6 and truck manifolds. what clutch do you recommend. i had a spec stage 2 on my 04 GTO and didnt like it much.
Old 08-19-2009, 08:40 PM
black98ws6ta's Avatar
I have good luck with the Spec stage 4 clutch. That turbo kit looks very nice to me.
Old 08-19-2009, 08:44 PM
lifeisgood's Avatar
im very happy with mine
Old 08-19-2009, 10:25 PM
99Z28LS1's Avatar
J
Great guy to deal with, kit looks supperb!
I can't wait to get mine and strap it on
Old 08-19-2009, 10:56 PM
MiaSSmaro98's Avatar
ive been reading good reviews on the monster clutches
Old 08-19-2009, 10:58 PM
Yes, the TTI street kit is limited. They will make some power but at a big exhaust backpressure level. Stock clutch's dont hold very much for an extended period of time.
Old 08-19-2009, 11:04 PM
dudeman's Avatar
yup, thats what i am thinking.
Old 08-20-2009, 03:10 PM
i been reading about the monster clutches. the stage 4.5 seems about what im looking for, but i dont like the idea of a "puck" style. they say no chatter, but idk. oh the kit from josh at kentucky said the manifolds arnt included. or maybe i just read that wrong.
Old 08-20-2009, 03:37 PM
XtremeDime's Avatar
The manifolds are stock truck manifolds, flipped around, i believe. They can be had for less than 100$
Old 08-21-2009, 07:29 PM
does anyone have info on the Installation Instructions on the KYTP kits.
Old 08-21-2009, 08:09 PM
trans2000am's Avatar
the kit is so simple you dont need install, just a couple pics an you should be good to go.
Old 08-21-2009, 08:40 PM
well i was looking for the small techincal stuff. how to tap the oil lines, torque values, all the little stuff. just dont want any suprises.
Quick Reply: Starting my Turbo build
