ls2 and 24x reluctor wheel Question
using a 24x reluctor wheel and an ls2 block. ive read and know i need a 2x 3 bolt ls2 style cam gear so it mates with the ls1.
is there ANY AT ALL modifications needed to the PCM to do such a swap?
reason i ask is im using a msd 6010 box for this setup, and it has NO programming whatsoever.
if extending the cam sensor wires and buying the proper pieces is all it takes then im good to go.
just want to make sure there is no PCM tuning needed to recognize the ls2 cam sensor with the ls1 wheel.
