ASP or SLP 25% underdrive pulley?
Old 08-21-2009, 01:53 PM
Abdullah's Avatar
Default ASP or SLP 25% underdrive pulley?
which one will give the best horsepower ,ease of installation and quality?
thanks.
Old 08-21-2009, 01:58 PM
01ssreda4's Avatar
pulley is a pulley is a pulley.
Old 08-21-2009, 05:41 PM
99TransAmLS16Spd's Avatar
As he said. It may even be worth looking at an ATI 10% underdrive. I replaced my ASP pulley with one of these. Granted I may have lost 15% underdrive, but I am guessing the rotational mass I'm saving (ATI weighs signifigantly less than the ASP) and true damping make up for it
Old 08-21-2009, 09:27 PM
PontiacFan's Avatar
Not sure if the ATI or ASP have high sides or not, but the SLP does.
Suppose to help reduce "jumpin' belts", ...
No, I'm not promoting one over the other when it comes to the hp, installation, & quality as you've mentioned. There shouldn't be any difference there.
Old 08-21-2009, 10:16 PM
Brandon35thSS's Avatar
never had any issues with my slp pulley and havent ever had an asp or ati so i cant say.
Old 08-21-2009, 11:23 PM
Good point on the side walls.
Install will be the same for the most part, except the ATI is a two piece, with the balancer bolting to the hub (does not make it more complicated)
As far as quality goes, ATI is far and away the best of the three. Thats not personal opinion either, it's simply in the design and the fact that its a true damper and not just a balancer. However, its probably not needed on most h/c/i non stroker motors.
Old 08-22-2009, 01:15 AM
ls2supersport's Avatar
plus 1
