No forward gears
No forward gears
OK heres the deal. Rebuilt my tranny a few months back with alto clutches and have every billet piston and servo in the tranny. I was pretty hard on it on the way home.Came to an intersection went to give it some gas and just revved like in neutral. So i went through all the gears to see what all was there.Only reverse...luckily i was only 10 houses down from my house so i turned around and drove in reverse home.lol
So anyways, what are some possibilities that might be the culprit of loss of forward drive?
sounds like the forward sprag broke
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Speaking of, if the output shaft was broke, how would it go in reverse with no noise? And if the new overrun and forward clutches did go, what would cause that? Cracked piston maybe?
Another thing is the teflon orings on the output shaft, would they cause any related problems?They were the only thing that i didnt replace on account of not having the resizing tool.
as long as the seals were not damaged they should have been ok its hard to say what failed and the reasonfor it untill you getit apartand see what happened
__________________
ok update. Tore it down just now and the forward spag assy. is in peices and the overun clutches are coned really bad with next to no clutch material left.This was just a quick inspection but seems to be the failure point. Now where do i go from here?What would caus this?Just weak stock parts or did i overlook something when i rebuilt it 4 months ago?
drill it out to around .096
__________________
volume...if you get and HD2 kit it will walk you through all you need to know I started using the HD2 kit on my personal builds about 1 year ago switched fro mthe superior kits and i love the hd2 its a no brainer....
__________________
