do i need longer wheel studs?
Old 08-24-2009, 07:43 PM
blackls1ta00's Avatar
Default do i need longer wheel studs?
i have front drag lite skinnys 15x3.5 1.75 bs and even with spacer they dont fit about 1/2 inch too small on the stud,do i need longer studs on the front?how about on the rear with 15 x10s 6.5 bs?
Old 08-25-2009, 11:10 AM
chrysler kid's Avatar
yes, or you need to order longer lug nuts. either way you need to order new lugnuts with the longer studs you will need open ended lug nuts
Old 08-25-2009, 01:17 PM
pozesd99''s Avatar
i would get some longer arp wheel studs and then an open ended mag style lug nut
Old 08-25-2009, 03:54 PM
wheelczar's Avatar
How much thread engagment are you getting? How many turns on the lug nut/stud?
Old 08-25-2009, 05:29 PM
i did not try the lugs that came with wheels they are are long and closed ends,the stud is about a half inch from inside the wheel.
Old 08-25-2009, 05:44 PM
pozesd99''s Avatar
thats not safe... to much weight on the end of the stud. it will snap
Old 08-25-2009, 07:12 PM
i didnt put the wheels on because of short wheel studs.
Old 08-26-2009, 01:35 PM
shtnfrds's Avatar
get longer studs and open end nuts. problem solved.
Quick Reply: do i need longer wheel studs?
