wtb rods and pistons ...have questions
if the 4.8 and l33 pistons are the same how to accommodate for the l33 having floating rods? i either need 8 4.8 pistons or a set of l33 rods and pistons can anyone help me here?
You should be able to use the l33 pistons on your stock rods as long as the wrist pin dia. is the same. You would just have to have them pressed in. Same process as using aftermarket pistons on stock rods. The rods determine if they float or not BUT some stock pistons usually don't have provisions for wrist pin locks that would allow them to be used with rods that allow the wrist pin to float. I have experience with other engine's I would assume the ls series would be the same.
