92 Buick guages in a 71 Chevelle
It looks like the 92 Buick Roadmaster and Park Avenue Clusters may be around the same size as the sweep dash in my 71 Chevelle. Have any of you tried this? I've seen several clusters for f-bodys and GTO's used. I dont think they will fit as well as this one might. The wiring may be tough and I need to do more reaserch to fully understand this swap.
The motor/ecm im using, are out of a 2001 firebird and I expect the cluster uses cam serial data to drive the gages. I expect the old Roadmaster gages dont use serial data. So each gage will have to be wired individually to sensors and the Speedometer and Tac have output from the ECM.
Let me know if any of you have tried a swap like this and what were some of the problems you encountered?
Thanks
Thanks
