Conversions & Hybrids - MSD 6010 box users step inside
View Full Version : MSD 6010 box users step inside
Z28/2002
08-29-2009, 07:10 PM
Got the box hooked up and running on the CETA but haven't started on the timing side of it yet. Currently have one of the pills in it to drive around on.
My favor from you: Who wants to send me some files so I can get the timing around where it needs to be? I've got the new Pro Data software from MSD ( v. 3.19).
Here is a little run down on the setup
Stock cubic inch LS1 with forged rods and pistons(-2cc reliefs)
PRC Stage 2.5 5.3 heads
Magic Stick 3
Pacesetter long tubes
Victor Jr with a 750 AED carb( jets are 88s all the way around)
Holley Black race pump
Edelbrock Performer RPM kit that will be jetted for a 150 shot(won't be sprayed until all the bugs are worked out)
Built TH350 with a PTC 3300 nitrous converter
Stock 10 bolt with 4.11 gears
Any help would be greatly appreciated:D
S10xGN
08-29-2009, 08:12 PM
I'm still "playing" with my setup, running 12° @ 0 RPM, 28° @ 1000 RPM, 34° from 2400 to 5800, and back down to 28° from 7000+. I have a MAP and that's setup as well. I can't believe you're running 88 jets around! I'm fouling plugs with a Holley HP750 with 70's in the front. I had to run a stock heat plug and larger gap than what the "racers" here recommended just to keep it running. With a TSP Torquer V.2, it pulls 9" vacuum @ 950 RPM's...
djquik88
08-29-2009, 08:56 PM
I was running a 6.0 LQ4 with l92 heads , Vic. jr. with a 870 cfm Pro-system carb. 76's in the front and 86's in the rear. I started mine off at 18* @ 0 RPM and 36* from 1500 RPM on. Keep in mind I was only at about 9.8 comp.
djquik88
08-29-2009, 08:58 PM
BTW , Nice Maverick !
Z28/2002
08-29-2009, 09:45 PM
thanks for the replies guys. i'm running TR6s in it gapped at about .038 and they look great. I've also got the MAP hooked up on it.
I've heard that the carb LS motors like timing around or below 30*. I'll be turning it to 7K on the shifts
LS1MCSS
08-30-2009, 01:31 AM
I have mine at 28 degrees max, and drop 8 degrees when the nitrous is activated.
topher455
08-30-2009, 01:22 PM
For some reason people always say "no more than 28* because blah blah blah fuel injected blah blah" 32*-35* seems to be the sweet spot from about 3.5k on up. 0 rpm 17* 1k 23*. Ant thats with 11.1:1
TJ
08-30-2009, 03:15 PM
youll find that a squared jet setup is going to be RICH on the street and youll never get it lean enough for cruising.
drop the front jet and toss a powervalve in it.
i have NEVER been able to run a tr6 plug with a carb and an ls motor. either on the edelbrock or an msd box.
terrible cold drivability, and pops and bangs once warmed up.
if you run into similar issues, check out an autolight 605(5 heat range) or a 103(6)
i currently run a br7ef in my 408. they seem to be the best lasting plug as far as fouling.
they seem to take more timing than other plugs as well.
Z28/2002
08-30-2009, 04:50 PM
Keep it coming guys. I know that it will be a trial and error before I find the right tune but this is giving me a starting point.
I would rather have the carb a little rich than lean out on nitrous and the AED I have doesn't have the powervalve in it.
I have been running TR6s in it since I did the conversion and haven't had an issue as of yet.
LS1MCSS
08-30-2009, 06:23 PM
My reason for not going over 28, is I have a lot more than 11.1:1 compression. Mine is 12.7:1.
TJ
08-30-2009, 06:30 PM
im talking about cruising down the street.
it will be hard to get a lean cruise out of it and it will more than likely kill plugs without notice.
my AED ran in the 9's a/f without a powervalve.
i sent it in for them to modify it for a power valve channel, then had nothing but problems out of it. even then it was so rich you had to change the plugs everytime you cranked the car.
trying to work the bugs out but it pops and bangs on the street. sent it back to AED and they are telling me the power valve channel is too large and its costing me 180 bucks out of my pocket to fix their mistake they said they didnt do. "someone modified your carb." no chit??
i will avoid AED. their customer service and support is horrible.
the attitudes of them on the phone is borderline.
im glad i didnt have to deal with them face to face....
hope your results are better than mine.
ive got an 1100 dollar paper weight im going to have to sell for around 500 bucks.
xpndbl3
08-30-2009, 08:00 PM
tj just go out and buy a quickfuel main body for a 4150 carb and then put in the proper sized passages if needed.
TJ
08-30-2009, 10:11 PM
its a 3 circuit carb. no can do.
its comming back to me and getting sold.
i have been informed by aed the carb is made to idle and run wide open, and will never run on the street without killing plugs. so its getting advertised as a drag race piece.
ive since bought a braswell and the car totes the tires 12-18" now.
1.36 short time, all motor.
xpndbl3
08-31-2009, 11:10 AM
ick well they really screwed you on that piece then.
NOPANTS-68
08-31-2009, 12:40 PM
6010 user as well
my combo- 2002 LS1- Trex cam- Edel victor- 650DP holley
I'm new to tuning with this software as I just got this car running, but I think I'm getting closer. I've got 12* at 0 rpm, 22*@ 1000, and all in at 3000 rpm at 28*, but the MAP is adding 3* under WOT. It seems much happier with the 650 on it than the 750- just a little crisper under light loads I'm sure due to signal and velocity. I've got 70s and 76s in it now with a 6.5 power valve. I had a 4.5 in it and it seemed better around town. It pulls right at 9-10 inches at 1000 rpm on a vac gauge. I put the 6.5 to try it and some new TR5s and now it pops and bangs under light loads. It's pretty angry at WOT so I know I'm close. The wideband will be here in a couple weeks, but I want to get a decent baseline for now. Looked at the plugs last night after just one day of light cruising and they are sooty with a tan powder on the strap. Looks to me like it's fat. What do you guys think?
ramdaspadhye
08-31-2009, 12:56 PM
Its either fat or you've got the wrong gap, one of the two. LS motors seem to be pretty sensitive to the proper heat range...
What are you guys running as far as the brand plugs and gap?
NOPANTS-68
08-31-2009, 01:14 PM
these are NGK-R TR5s gapped at .032. I'm gonna stick the 4.5 back in it tonight and some 67s up front and see what happens.
S10xGN
08-31-2009, 09:15 PM
The (racer) recommendation on here was TR-6's @ 0.030". I tried that and fouled every plug so bad it wouldn't crank. I'm now using stock heat-range Autolite AP5245's gapped @ 0.045" and it's much happier. Still pig-rich at idle, even with a 4.5" PV and #70 mains...
TJ
08-31-2009, 09:52 PM
does the main body have removable idle bleeds?
if not, you can drill them, but i dont like doing that unless they are removeable.
that will help cure some issues.
also, if you butterflys dont have holes in them, you can drill .090 (or 3/32 bit, easier to find)
helps lean it out some too.
TJ
08-31-2009, 09:54 PM
OH YES.
got it back today. looks like its been sitting 40 years in a bucket of acid.
i didnt want to spend 200 bucks to have it recoated, so i guess they stripped it to further prove a point.
ill have to send you pics of when it was on the car and what it looks like after i got it back from them.
my god.....
NOPANTS-68
09-01-2009, 12:24 AM
the last tune I tried tonight ended up being the best. I used a 6.5 power valve, 70s and 74s, and 3/4 turn out on the idle mixture screws which gave me almost 13 inches of vac. It seems to idle the best and run the hardest with this combination in a 650DP. I heard it pinging on the big end so I'll back it down two degrees to 30 tomorrow. It feels like 100 hp difference from yesterdays 67/72 4.5PV.
ramdaspadhye
09-01-2009, 02:49 AM
650 or 750? I got a BG 650 with the 6.5 pv and 70/78 jets from the factory. Motor's not built yet, but hopefully I won't have much tuning issues. Not gonna spin past 6k til I can upgrade to a larger carb.
S10xGN
09-01-2009, 10:25 AM
Yup, and I've already gone up to #75's from the stock #71's and didn't see any change. My idle screws are 5/8 turn out from full in. I guess it's time to step up even larger... I've got a WB kit, but haven't had time to mess with it yet.
NOPANTS-68
09-01-2009, 01:35 PM
650DP- santa's bringing me an HP750. Gotta make do with what I have for now.
Z28/2002
09-01-2009, 02:58 PM
Looks like I need to invest in a jet kit
TJ throw a couple pics up of the carb
topher455
09-01-2009, 08:13 PM
For clarification I wasnt saying you were wrong by not passing 28* I just didnt want him to stop there without trying to get all he can out of his combo. Your setup is definitley not run of the mill either. Its pretty badass if I do say so myself.
TJ
09-04-2009, 06:41 PM
sorry. been slammed at work.
i cant find any pics before hand, but it wasnt a perfect carb. well it was, but i had rebuilt it and drilled and changed jets, restrictors, etc per AED.
sent it back to them and they didnt even clean the main body. still has black chit all in it from the backfires id have.
the main body was bright silver, now its almost black. that look when aluminum gets hit with a harsh cleaner.
i sprayed it down with carb and brake cleaner a thousand times and it didnt look like this at all.
strait back from AED out of the box.
even the idle misture screws have some red staining in the knurls of the head of the screw. appears to be rust, IMO.
i should add that i did NOT want to pay 150-200 bucks to have the carb stripped and recoated to as new condition, so i told them to send it back to me as is.
guess they got me....
i have yet to run it, but i am told it is good to go.
not sure if im going to use it or sell it yet.
http://i102.photobucket.com/albums/m108/stage20/DSCN2446.jpg
