headers and ls6 intake,now a vacuum leak?
I am almost positive i didnt miss and hoses or electrical connections.i checked everything about 4 or 5 times before i started it.When you go down the road it hangs up at 2000rpm until you come to a complete stop and even then it takes it a couple of seconds to come back down.would this be a vacuum leak or could it be something in the tune?or the fact that its just straight headers?i torqued all the intake bolts down to 89 in/lb and in the proper sequence and used brand new gaskets.
I would say tune. I have had several vacuum leaks, small and big. Small ones will idle a tid bit rough and eventually throw a code for lean/rich condition on both banks. Big leaks will cause insanely rough idle. Like it will sound cammed and run like poop. I'm going to say you need a tune as long as it idles smooth. But check the brake booster hose and the PCV system, those seem to be popular places to develop leaks. Hope that helps!
Ya know it kinda does sound like its got a bit of a cam.but thats probly because the tunes off and i drove it on straight headers.the brake booster line was good and i re did the pcv system with a catch can.and yes i kept it sealed.im going to borrow a tool from a friend tomorrow that you hook into a line while its not running and it pulls vacuum while the engine is off so you can hear it
If it is dirty, just remove the throttle body and put it in a bucket of gasoline or carb cleaner. Should break down most of the nasty. Then wipe it off real good with a clean cloth. If it still sticks, put a SMALL shot of WD40 in the spring closer to the throttle body. Don't spray it in the inside of the throttle.
The throttle operates smoothly.Ive checked that.i cleaned the throttle body with pb blaster and it still does it.ive pretty much narrowed it down to a vacuum leak.i borrowed a manual vacuum pump so im going to hook it up sometime and see if i can hear a leak.
Also i was wanting to remove the cruise control because it doesnt work anyway.if i were to do this which cable do i hook up to the throttlebody?
"i sure am glad i have another car to drive.this thing is obnoxiously loud with open headers."
How close to the end of the collectors are the O2 sensors?? The idea of it being a vac leak, may be O2 sensors being hit w/ "raw air"...
Suggest you install the exh system and see WTF happens then.
That also crossed my mind.they are only a couple of inches away from the end of the collector.i am taking it to the shop who is fabbing my exhaust today because they are all going to be there just hanging out and the guy said he would throw it on the lift so he could see what kind of bends to order.im hopin to get the ball rolling on it by the end of next week.the exhaust still needs to be done and it still needs to be tuned before the lsx shootout.if its not done im not going.ill be damned if i had to drive my honduh prelude.
