If you have a upgraded clutch+flywheel please step inside..
Im shopping for a new clutch and flywheel setup..
So far I like the UUC flywheel because its dual mass ( just like stock i think ) and I know there wont be any fitment issues or slave cylinder problems..
Just dont know what clutch to run with it? Spec ? any others out there that will fit?
If the clutch is made to fit the stock flywheel, it is safe to assume it will fit the UUC ?
I dont want any fitment issues.
please post up your setup and how you like it.
I also looked into the monster kit but its over $1,000 for the aluminum flywheel kit and it just seems a but steap, im tryin to see if it would be cheaper to piece together my own.
Any one running a spec flywheel and clutch ?
I can get a stage 2 clutch and single mass steel flywheel for $615 .
Plus I think it will need the $100 spacer ..
Any good or should I spend the $1,000 on the monster setup?
one of specs employess actually has a cts-v and he runs a stage 3.5 kit on it. He states that the setup will come with everything u need to bolt it up, spacer and everything.
Ya thats what i want, I see alot of threads about ppl hunting for shims and spacers..
Other thing that has me worried now is bleeding the thing...sounds like a pain in the ***..
The Monster clutch kit is a bolt in deal with no guess work.
They also have billet steel flywheels, 18 and 28 lb versions (made in the USA BTW)
Give them a call and talk it over with them.
Great guys, tell them Chris @ Gforce said to call
