Best angle for adding rearend fluid?
lately i have been noticing that the rearend has left a few drops now and then after a hard racing/launching
i was wondering what would be the best angle to have the rearend in when just adding fluid do i need the front on the car up too and do i need to lift the car from the chassis or the rearend? thanks
it does sound like a pinion seal might be leaking and the best way to put fluid in without putting it on a hoist is a small pump like INMY01TA had mentioned, i had the same problem and that what i did with a lil pump!
