Squeaks
Old 11-28-2003, 06:44 PM
WS6 RULES's Avatar
Question Squeaks
My 02 WS6 has started bad squeaks when I drive slow over a bump like a speed bump. Any ideas on what it is and how to fix it. Is it my shocks?
Old 11-29-2003, 07:32 AM
STF Veteran
99-LS1-SS's Avatar
Wait until the car is 4 years old. It sound like a heard of angry mice on crack.
Old 11-29-2003, 08:42 AM
Cheatin' Chad's Avatar
Old 11-30-2003, 05:16 PM
glitch77's Avatar
Squeeks? It may be the rubber bushings in you LCA and/or panhard rod. Does the sound only come from the rear? If so, its most likely bushing noise.
If the squeeks care from the front, there are a few bushings that could be the problem, or a shock may be making noise. (Mine was). Good luck!
Old 11-30-2003, 05:30 PM
Mike K.'s Avatar
just start upgrading stuff in the area of the squeak until its gone haha. Probably is a bushing though as already said.
Old 12-01-2003, 06:30 AM
mitchntx's Avatar
The squeaks are typically from metal on rubber.
I would suspect the sway bars.
Old 12-01-2003, 12:08 PM
Moderator
jimmyblue's Avatar
Is there a good rubber-safe grease, maybe graphite-
or MoS2 loaded, that people recommend for bushings &
sway bar mounts?
Quick Reply: Squeaks
