Forged internals stock block
Old 09-14-2009, 03:32 PM
nasty_ss's Avatar
Default Forged internals stock block
i want to put forged rods and pistons in my block. i'm reading the sticky for the ls1/ls6 dimensions and i am a little confused as to the sizes i need to buy to keep stock bore on my block while also using stock crank. I've noticed there are 6.100"and 6.125" length rods. which do i need to go with? pistons i think i've got down for bore. i'm assuming they're going to have to be the 3.898" size. is this correct? could i use a 3.905?
Old 09-14-2009, 03:46 PM
NemeSS's Avatar
do u plan on assembly of motor yourself? by your post, it seems that you are not familiar with basic engine math. u can use either 6.1 or 6.125 rods. with stock crank.
Old 09-14-2009, 08:24 PM
99SSAGUI's Avatar
look up 347, this will be your new CID since you can not use the standard 3.898 bore pistons unless you have a new block. Your block will need to be honed I think someone makes a 3.903 piston, but I am not sure. I am currently in the process of purchasing parts for a 347 and I use the 3.905 JE pistons with 6.125 rods (you could use 6.100 rods). wherever you do make sure you plan ahead and set a budget to avoid wasting money and time.
Old 09-14-2009, 08:33 PM
nasty_ss's Avatar
i def plan on having a shop put it all in. because i'm new to messing with internals i don't want to mess it up.
Old 09-14-2009, 09:04 PM
nasty_ss's Avatar
awesome. thanks for the info.
Old 10-13-2009, 01:25 AM
nasty_ss's Avatar
how much should it cost me to have the pistons and rods put in and blanced on my crank with the hone.
Old 10-13-2009, 02:30 AM
stevied916's Avatar
hone/bore with plate is around 250
balancing is around 225-250
you need new cam bearings around 60 installed
new main bearings 60-100
shortblock assy around 300
if you need a line hone about 150
if you stick with press fit pistons it will be 80 to fit them as well.
It depends on how much you want done...it adds up fast
Old 10-13-2009, 02:06 PM
DONAIMIAN's Avatar
It would probably be cheaper to just buy an assembled short block and sell off the one you have now...
Old 10-13-2009, 02:38 PM
franksaltz28's Avatar
this is very close to what it will be. I spent 2600 to get my shortblock 383 done. thats everything from crank to labor.
Old 10-13-2009, 02:57 PM
LS1TECH Sponsor
Schwanke Engines's Avatar
http://www.schwankeshortblocks.com/Short%20Blocks.htm
We can do a forged rod and piston Iron 5.7L for $2299.99, or an aluminum block 5.3l/5.7L for $2599.99
