what are the dangers or problems with overfilling a bottle?
i got my own cylinder so i can save a few $$. it is a 65lb cylinder and so far i have pulled 35lb out of it effortlessly by just freezing the little bottle and warming the large bottle. i have a heating pad on the large bottle, even leaving that on there in my cold garage i only see about 800psi
my question, the nx bottles are 15lb empty and 25 full, i had it down to about 20lb's i figure i would top it off, by using the method above i got it up to 28lb's or 13lb's of nitrous in a 10lb bottle. is this dangerous? should i stop it at 25?
i am anxious to see how much of that 65lbs i can get out without a pump by just freezing the little bottle. so far it is awsume having my own set up.
we have filled them up more than 10 pounds before. main problem is keeping the pressure up. usually it drops rapidly with more than 10 pounds. the best way to fill the bottle is to have it freezing cold and to siphon the nitrous in there fromt he other bottle without using a pump. tha way u can get almost 100% pure liquid nitrous
The shop I go to will fill mine to 11 or 12 pounds but he wont go over that. Its nice having that initial higher pressure. Ya do have to wonder how many extra pounds it will take to pop that bottle and send all your limbs flying. Of course we do have those pressure relief dealys. I dont wanna be around when one of those pops either though.
