Manual Transmission - LT1 T56 bolt/nuts specs
View Full Version : LT1 T56 bolt/nuts specs
steve000
09-15-2009, 12:18 PM
Does anyone have the specs to the below bolts/nuts, I acquired a t56 but it didnt come with any bolts. Went to the dealership and they went of much help, every other item was discontinued or in a pack of ten.
Thanks
4 12337828 Screws for flywheel cover $0.37
6 10079898 bolt for pressure plate to flywheel $1.78
6 10198997 bolt for bell housing to engine $0.43
2 11506117 nut for slave cylinder M8x1.25/with washer
1 10121502 retainer for clutch reservoir $0.17
1 14076942 u-bolt for clutch master cylinder
2 11515748 nut for u-bolt M8x1.25/with washer
2 11500323 washer for nut for u-bolt $0.37
1 10252375 bracket for torque arm $14.23
1 11500046 washer for torque arm $0.37
1 11500930 bolt for torque arm bracket $1.01
1 11504745 bolt for torque arm bracket M10x1.5x8x40
2 10255857 nut for torque arm bracket $1.28
2 22570841 bolt for transmission mount M10x1.5x30
Gen414
09-15-2009, 06:39 PM
Thanks
what specs are you looking for? :confused:
steve000
09-15-2009, 07:58 PM
The length, pitch etc
jmd
09-16-2009, 10:30 AM
PP to flywheel is 3/8-16. You can use a half-threaded length bolt (just make sure it's not bottoming out in the flywheel. Try and get the non-threaded portion similar to stock)
If you need the transmission to bellhousing bolts (same as the ones holding the tailhousing on) I bought more than I needed recently in grade 8 (slightly higher grade than stock) with the flange hex in black. Just like stock.
