Cam condition and install Question
This is probably a easy question to answer, but I have heard many different things so I want to get some advice from you guys. I purchased a used MS4 cam and it appears to be in good shape. There are marks on the lobes from the lifters, but no pitting what so ever. The cam has been checked and all specs check out, but my concern is the marks on the lob. The cam was used for under 3K and taken out and you can see where the lifters ran. Is the cam still usable and if so is it safe to use my stock lifters or new lifters since I do not have the old ones? Thanks for your help.
You should be fine. Every cam i've seen has the roller marks just like you described. Search for some used cam pics on here and you'll see the same.
You're stock lifters should be fine as well. If they had super high miles I would replace them. Since they'll be worked harder with stiffer springs and faster lobes. Then again i've seen 130k+ motors get big cams thrown in without issue.
