have problem starting car still
Old 09-17-2009, 08:41 PM
pdasterly's Avatar
Default have problem starting car still
converting v6 to ls1. So far the engine, trans and rear is mounted. I have a new under hood relay harness along with a new interior harness. When i turn the key the starter will not engage. I can jump the starter via the relay box under the hood. I can touch terminal 87 with 30 and the car will start, but not with the key. I have efilive and have disabled the vats security. dont know what to do at this point
Old 10-12-2009, 07:42 AM
irocbrninrubber's Avatar
I am having the exact same problem. Did you fix it? what was the problem? Thanks
