AFR heads
Old 09-18-2009, 04:16 PM
forcd ind's Avatar
Default AFR heads
right now i have an LQ4 with Pats. Perf. stage 2 heads and Procharger-i am building a 403, i was looking at the AFR 215's, or reuse my Pats.
would i gain enough to make it worth the money-i thought about even the
L92's, although some say that the deck is thinner, wether thats been an issue i dont know
mostly a street car
Old 09-18-2009, 05:37 PM
Restricted User
98Z28CobraKiller's Avatar
mostly a street car
I would go with a minimum of a 225. The bigger 235-240 heads are supposedly right around the corner.
Old 09-18-2009, 06:01 PM
TT-TECH Veteran
Inspector12's Avatar
TFS is all I am going to say lol! No I have both and the AFR's are good also, but if I was buying new then I would go with the TFS as I think they are a tad better and you have more options as well as being a little cheaper. I personally would stay away from a factory castings if you are going to push it. If not then they are a decent option for sure and can be had for dirt. GL!
Old 09-18-2009, 06:16 PM
EPP
EPP's Avatar
I agree, AFR 25 heads are what I have on my iron block/ProCharger F-1C Camaro, shown here.
http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old 09-18-2009, 06:42 PM
NemeSS's Avatar
the dart 225 flow pretty good as well, have a thick deck and are around 1k cheeper the the abc heads. i would use thm in place of a oe head, for psi
the afr and tfs are top notch but unless the car is all out competition, i dont really think there necessary.imo
Old 09-19-2009, 07:24 AM
forcd ind's Avatar
i took a look at the Darts and TF's, they dont appear to offer a 72 cc head, only AFR
Old 09-19-2009, 05:42 PM
TT-TECH Veteran
TFS come in a 72cc the only one that doesn't is there 215's.
