11.79 First time at the track W/ Video
Well, I am happy to say I am a proud member of the 11 second club as of tonight. Ran three times.
Pass 1) 12.2@112 All motor 1.86 60'
Pass 2) 11.79@115 75 Shot 1.68 60'
Pass 3) 12.00@115 75 shot (car would not shift out of first banged off the limiter for a while)
I am shocked to see I only picked up 3MPH on a 75 shot but nearly .5 in the 1/4. Does this seem right? The car is full weight down to the spare tire and jack. I also weigh 270Lbs. So I think I need to drop 100lbs and pick up some ET lol.
I think once I get tuned a good intake on the car. I should run a bit faster with a 150 shot on the car also. I only sprayed the 75 shot do to not having any sort of tune in the car.
Car mods:
Tsunami Cam
L/T Headers
O/R Y
3:73 gears
Yank PT3800 Stall
75 Dry Shot
30LB Injectors
Racetronix pump
NO TUNE
The car is still untuned and has a stock LS1 Intake and Throttle body.
EDIT: Slip Added
Video for your enjoyment.
http://www.youtube.com/watch?v=dUzx3DvIX3A
P.S. I beat the mustang as an added bonus. My Buddies 4 year old son is very concerned I am about to loose to the Mustang to hahaha.
Car mods:
Tsunami Cam
L/T Headers
O/R Y
3:73 gears
Yank PT3800 Stall
75 Dry Shot
30LB Injectors
Racetronix pump
NO TUNE
EDIT: Slip Added
What kind of tire were you on? Can't watch the vid since I'm at work, but I'll check it out later. I'd be pretty happy with the times on motor since your tranny is shot, you are untuned, and you are still have LS1 intake.
I would think a good tune and better intake would easily put you in the 11's N/A. And add the 150 shot to that should be bottom 11's maybe high 10's? Still bone stock suspension? If so once you are spraying bigger, tuned, and have an intake the suspension might be the next thing start modding. Or just throw a D1 on it.
I thought I was going to blow my trans for sure at the track. But, it held up well and only slipped a tiny bit. I think that is why I can not get a better 60' time. I do not spin but the trans does slip a bit out of the hole.
I have BMR LCA's and BMR Subframes.
The car does have a tune in it. But, it was before the Cam, L/T's, O/R y, Air and EGR delete. It actually still has active traction control. It was only tuned for the gears and injectors that are in it.
I am going to get it tuned soon though and Spray 150 shot on it for sure. I think once I have it tuned I will slow down a bit in the 1/4 all motor due to more timing for the nitrous.
All in all I am happy with it. I just need to keep spending money hahaha.
Your lucky that 75 shot of NAWWS didn't blow the welds on the intake manifold.
I would think a 75 shot would pick up more than 3 mph on your trap, it may be your trans slipping when you spray it??? You should be in the mid to high 11 on motor with a better intake combo and a fixed tranny.
We need to meet up some night before i go to work (workin 3rds atm) so i can check your car out.
or now that i think of it are you sure the spray was held for the whole pass... you picked up .2 on your 60 foot on spray i could see that getting you the .5 on the top end maybe you only sprayed for roughly 100 foot out and you ran out of bottle pressure??
Yep, it sprayed the whole time. I have a new intake, throttle body and a second stage of nitrous now. I am going back to the track to run some 10's and get kicked off the track.
Call me some time before you go to work. You can come over to my house and check the car out.
