Coupler Help needed (Fast Toys 98mm lid)
I have a ws6 lower airbox and I am switching over to speed density tune, and I can't seem to find a coupler with the proper bend it to go from the lid to the tb. Right now i have a 4in coupler that is straight and is 6in long but it has kink in it. I have fast 92mm setup on the car so the inside diameter of the coupler needs to be at least 4in. What is everyone using, I have used the search button and I have also searched the web and have come up with nothing.
Moderator
A silicone charge air cooler hose works great. Has good flexability and easy to trim to allow a better fit.
http://www.goodyearep.com/ProductsDetail.aspx?id=10422
Check your local semi-truck repair shop they usually have these in stock.
