msd 2 step launch controller
well i would like to hook connection to the clutch switch, which i would think its by the clutch pedal. but was wondering how the clutch switch works, does it have power all the time and push it down and makes contact, or does it work by pcm ground, and is the clutch switch one wire or two. thanks in advance
well started to install, and took like 15 seconds to plug into the coils and tommorow i figure out the clutch switch, i think i can tap into it in the engine compartment, at the pcm i think i know what wire it is. i post up when i get it done and working. but i hook it to a 12v power source and tested, it is awesome
I have the same, issue spent last 30 mins taking clutch switch apart and such, I'm not sure how it works, both wires are always showing ground on the clutch switch and no positive. I'm about to just over ride the clutch switch to not be need to start the car and run a ground to the clutch switch and just plug in my 2 step to other side and work on switched ground.
I didn't go with the Lingfelter one because I read to many issue people were having.
well i have the msd and it was easy to install as of getting it to work, just hook to the coils and went to a 12v and worked, but want to go to the clutch switch, just tried it out, to make sure it worked. need a pin out of the pcm for the clutch anticiapate switch
With this set up the car will start with out the clutch depressed so you need to be more careful. Fastest way I could come up with. Any other ideas welcome.
CARTEK Racing
Man... the LPE launch controll was so easy to install. If I had to sit aournd and figure out what wire does what I would have given up long ago. All I had to do was hook up the clutch switch wire and power. Done lol... Took me more time to decide where to place the box lol.
