Anyone tried Champion fans yet?
Restricted User
They are supposed to be as good as good as Spal fans....
Thinking about buying 2 (16" that flow 2500cfm) and puttin one on each side of radiator... $60 each
can post link but they are on crapbay....
They come with a guarantee also:
100% Money Back Gaurantee.We will refund (or exchange after 60 days) 100% of your money (Including All Shipping Costs) If: · Your fan does not fit
· Your fan does not cool your engine
· Contains manufacture’s defects
· Or for some reason you just do not like itYou can purchase from us without worry because our guarantee gives you unconditional protection · Contains manufacture’s defects
So what do you guys think? I think it may be a good deal!
Restricted User
16" Reversible curve blade fan out! Puts out 2200 cfm but only uses about 21 amps. Simple 1 nut holds the fan in place and is easily removed for quick reversing of fan rotation. Pull or Push in less then 1 minute. High quality blades are tie together reducing the flex in the blades and reducing noise. We have bought a truck load of these at a reduced price. Curved blade for less noise.
the amp to cfm rating on this fan seem dead on... so this one will more than likely meet its 2200cfm rating
junk dude if you want to keep oyur bird cool try the flex-a-lite S blade 398 i have two one 12" one16"" at 3800cfm never run hot
