Refninish flywheel & pressure plate?
Old 09-28-2009, 09:53 AM
Mike Bell's Avatar
Default Refninish flywheel & pressure plate?
I know you can get a flywheel refinished, but I'm not sure where. Any suggestions as to what kind of places do this? Also, can you have the pressure plate refinished as well?
TIA,
Mike
Old 09-28-2009, 11:29 AM
jmd
jmd's Avatar
Try a brake and clutch exchange. Guaranteed you'll have some truck brake relining services in Tulsa.
Yes, you should always try and have a refinished PP with a refinished FW. I've broken that rule (used clutch, new flywheel) but it's not your best bet by any means.
Old 09-28-2009, 11:38 AM
SPEC-01's Avatar
Mike, most good machine shops of the ability to grind a flywheel. It is a fairly straight forward process. There really isn't a way to machine the plate (without disassembling it first) and most shops won't offer this as an option. Are you using an OE flywheel now? Has it been machined before? Let me know and I will be happy to provide more info. Thanks,
