Hendrix-Engineering axle ready to ship!
Alright guys you can read the review from skull and make your desecion,we also had someone else test the axe and they felt like 99% of the issue was gone.Keep in mind i have never or will never sell the axles as eleminating wheelhop,they will drasticly reduce it for most and resolve it for others.This is by far the best solution with no side effects to the way your car rides.We will sell the first 10 for $299 that will include a inspection of your stock parts reassembling with our bar ,new boots and our grease.You can also have the parts shipped to you for $249 and assemble yourself.
I chose to replace the shorter axle ,leaving the longer factory axle to twist the most.This is the best shot at trying to run one axle and save the low hp guys the most money.On our pro level axles it doesnt matter what side the bigger bar is on because were replacing both.The reason i put the bigger axle on the passanger side in the pro set is to offset the weight a little.
Here are instructions courtesy of LollyGagger8:
http://www.cadillacforums.com/forums...e-install.html
ok so im kickin around with what i should get as far as a wheel hop remedy..bushings or axles..im not buying both!i only plan on putting maybe 400 to the ground when im done messing with this thing..(no $6500 blower for me!) how much do yo want for both upgraded axles shipped to CT?
