Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
is it possible to install motor mounts with long tubes on??
Old 10-02-2009, 11:21 AM
chadeberly's Avatar
Default is it possible to install motor mounts with long tubes on??
A friend of mine is installing mounts and wants to know if it can be done before he pulls headers. thanks
Old 10-02-2009, 11:35 AM
chadeberly's Avatar
please help!!
Old 10-02-2009, 12:17 PM
cobra29svt's Avatar
Yes, would be a easier job with headers.
Old 10-02-2009, 01:19 PM
raven154's Avatar
I pulled the headers on mine! I wouldn't even try with them on.
Old 10-02-2009, 03:43 PM
alan2000T/A's Avatar
post 3 and 4 directly contradict each other...so which is it? Obviously it would be easier w/ no headers on at all...but how difficult is it really w/ headers on?
Old 10-02-2009, 03:54 PM
jerrad's Avatar
Raven has swapped his a couple times so I'm guessing he might have more experience doing it.
Old 10-02-2009, 03:55 PM
lowaggie's Avatar
I installed my sphon motor mounts on mine without taking the headers off. It was a total pain in the ***, but I was able to do it in my garage over the course of two days. You just need to drop the starter/ac/alternator to make it just a bit easier.
Old 10-02-2009, 04:33 PM
maxspeed96ct's Avatar
I just installed my kooks 2 months ago, and now i plan on installed motor mounts next week.
Im kicking myself in the ***.
But im going to try it with headers on, I think with a good swivel socket combo and some extentions I can get it..
Wish me luck.
Anyone else do it without taking off the headers?
Old 10-02-2009, 04:59 PM
cobra29svt's Avatar
Mightymouse has swapped his out a few times with the headers on while making his motor mounts.
Old 10-02-2009, 06:15 PM
raven154's Avatar
Maybe I just like the extra work, but even though it seems like the longer route, removing the headers does make it easier. I dont like to fight things. I've tried to short cut things and not remove stuff and it never works out for me so I dont even try anymore lol It usually ends up costing me more time or money than if I would have done it right the first time.
Old 10-02-2009, 07:58 PM
here is a sort write up from the other forums...
no long tubes but figured id share it.
Old 10-14-2009, 07:26 PM
BUMP
anyone have a answer?
can they be installed with long tubes?
I dont see why It would be harder but i didnt get my hands in there yet .
Old 10-14-2009, 08:11 PM
raven154's Avatar
It would be harder because you can remove the cats off the manifolds and have plenty of room to work. The long tubes go all the way down and under the bell housing so there is much less room under there with headers.
Old 10-15-2009, 05:18 AM
That doesnt make any sence.
Because you dont have to remove the cats from the stock manifold to change out the motor mounts.
almost everyone has done it without touching any thing on the stock headers.
Old 10-15-2009, 06:33 AM
raven154's Avatar
Either way, instead of having one pipe, now you have four that take up much more room than the cat does. Why dont you quit asking and just ******* try it. Best way to learn is hands on. If you cant get them out with the headers on just pull them off! WOW how hard is that?
Old 10-15-2009, 10:37 AM
CTSV_510's Avatar
Old 10-15-2009, 03:04 PM
if the giant stock cat ins't in the way, then why would the pipes be in the way?
Id like info from someone who has done the install . Learning hands on is fun, but If I could get tips and shortcuts from some one who has already done is a big help.
Thats what the forums are for. The share helpfull information with other V owners not for bored ******** like you.
I assume you have never installed headers on the V , Its kind of a pain in the ***. So I'd like to avoid it if possible.
please dont trash this thread anymore unless you have some usefull information.
Old 10-15-2009, 03:25 PM
raven154's Avatar
See everything in my sig? Yeah, I installed it. I have turned every bolt that has been removed from my car. I've had the engine and trans out and in several times. I've changed motor mounts more than once with the engine in and out of the car. I've had the headers off more than once. Motor mounts are a big pain in the *** and I pulled the headers. You can do it however the **** you want.
Obviously you have never installed motor mounts on the V. Its kind of a pain in the *** and is much easier with the headers removed but I'm sure it can be done. Hey! What a novel idea! Why dont you try it and tell us how it goes since nobody here has done it with headers on! Gotta start somewhere!
Old 10-15-2009, 07:52 PM
^O boy another mikie niiicee
ya your such a big shot, to bad no one cares.
If you know it all then share, instead of posting things like go try it yourself..
We're just looking for a simple answer.
"Do you have to remove longtudes to install motor mounts. "
no one asked what raven thinks
Old 10-16-2009, 04:05 AM
raven154's Avatar
Wow, you are a douche aren't you!
Quick Reply: is it possible to install motor mounts with long tubes on??
