Drag Racing Tech
rear springs?
Old 10-04-2009, 12:31 AM
TJ
TJ's Avatar
Default rear springs?
i currently have v6 convertible springs in the car off a 2000 model.
they have been working great, but my drivers side is sagging an inch over the passenger side and are going to replace them.
whats everyone using in a grag setup, does it even matter?
going to the u pull it yard in the morning.
thanks.
Old 10-04-2009, 08:07 AM
Race your car!
JL ws-6's Avatar
I have stock springs in my car in the back, and they've worked good.
If you're staying with stock springs, just look for any stock 4th gen v8 spring it will be fine.
If you want to go with an aftermarket spring that you use an adjustable perch for, 150 lb is the rate you're looking for.
