Drag Racing Tech
block off coolant lines
Old Oct 2, 2009 | 08:29 PM
daniel6718's Avatar
Default block off coolant lines
i went to autozone and got some vac caps but they dry rot and crack and start to leak after a few weeks...what do you guys use?
this is for the heater core lines on the waterpump
Old Oct 2, 2009 | 08:56 PM
veee8's Avatar
Removed the steel fittings from the pump, and welded them shut. Some people have tapped the holes and screwed in pipe plugs.
Old Oct 2, 2009 | 10:01 PM
kierstyn's Avatar
I looped mine with a hose fitting.
Old Oct 2, 2009 | 10:15 PM
ninetres's Avatar
+1
About 6 inches of coolant hose and 2 clamps and WHAM, problem solved!!!
Old Oct 2, 2009 | 10:29 PM
airfix's Avatar
I Just pulled my hvac box tonight, and am looking for the best way to do this, I think I'll just loop it then next time I take of the wp I'll weld it up.
Old Oct 3, 2009 | 08:10 AM
daniel6718's Avatar
i looped it before and had air stuck in my system and couldent burp it...and its not nearly as clean...i also have this problem with a lt1 car...any other options?
Old Oct 3, 2009 | 09:12 AM
JL ws-6's Avatar
Race your car!
Tapping the openings, and threading in a bolt or whatever to seal it up would probably be best.
Old Oct 3, 2009 | 10:40 AM
SSPerformance's Avatar
u can also lope it
Old Oct 3, 2009 | 12:16 PM
InsaneAuto86's Avatar
I did the same thing. Worked for a few weeks then exploded when I was driving... I ended up welding the holes shut.
Old Oct 4, 2009 | 01:14 AM
daniel6718's Avatar
damn a tap that big is goana cost...what are they 5/8 and 3/4?
Old Oct 4, 2009 | 07:40 AM
JL ws-6's Avatar
Race your car!
Yeah, but it's a tool that you probably will only buy once in your lifetime, unless you do alot of heavy fab work.
Old Oct 4, 2009 | 10:06 AM
BAKED's Avatar
I cut mine off just past the "hump that keeps the fitting from going any further into the WP and I put plugs in them AND welded them from the backside so that when you see it, they just look like plugs.
Old Oct 4, 2009 | 11:44 AM
mrdragster1970's Avatar
6 & 8 Second Club
I had some trucks that I had to do the same thing. I armour alled them before installing.
They lasted years. I had planned to do it on a regular basis, but they never cracked on me.
I also only used distilled water?? maybe that helped??
