5.3 best cam choice
5.3 best cam choice
hi im swapping in a 02 5.3 into my 89 camaro. i was wondering what the best cam for the 5.3s is. ive done searches and there is alot of info. my setup is a ls1 intake for now manifolds possibly long tubes, 3000 stalled built 700r4 3.73 gears. any info i will be thankfull.
I've kind of been out of the loop for a little bit since I have no LSx vehicle, but I'm looking at picking up a 5.3 for a project of mine like you are.
Since both engines have the same stroke, if you have a hot cam for a LS1, it should work just fine in the 5.3. However, since the engine is smaller, a cam that might not seem big on a LS1 will be more noticeable in a 5.3. I'm not sure what your goals is, but I wouldn't go too crazy on the duration (but that's just me). My engine will be going in a truck, so I'll probably go with the Lingenfelter GT2-3, better than stock, and the smog guys won't notice. The stall and the gears will help out a lot if you choose a cam that's pretty lumpy. Good luck.
I
I
I have a 5.3l with a 222/222 .566/.566 112lsa, it feels stock-ish on the low end, mid range is better and top end is great, good sounding idle. It would be a nice cam for a car. Through a TH-350 it makes 331 rwhp at 6000-6200 and 315 rwtq about 4000-4400. I bought is from LPE, I think the part # is gt2-5. I am currently going to a 408 stroker to get a better low and mid range becuase this is in a truck.
thanks for the suggestions, im looking for around 400 hp and trq. ive been thinking of doing car crafts oct 04 build of a 5.3, consist of stock 5.3 long tube headers, lpe gt1-1 cam 229/242 .631/.631 and 114.5 lobe sep., comp cams behive springs lpe steel rocker stand 30lb injectors. with a truck intake, they made 369 trq. at 4800 and 413hp at 6600. im just wondering if anyone has done a similiar build and if so what is the drivability like.. i drive my car alot but i beat on it alot too so i need a motor that will perform, my current motor is a copy of a car craft build supose to be 401hp and 427 trq. its carburated and i want fuel injection. my current setup i run out of motor at about 1000ft on the dragstrip and have to shift into overdrive and thats at 5400rpm. i have a 5.3 in my seirra and i love how it revs all the way to 6k. thaks again
