WTB: 01-02 Electronic Brake Control Module (EBCM)
I am looking to buy an EBCM that is from an '01-'02 V8 car that had traction control and ABS. The one I am looking for has 10 "wave springs" they look like little cylinders.
Let me know what you got.
Thanks!
Thanks!
FYI, when you replace the unit, there is no need to take off the brake lines. There are 6 torx screws you and remove and change out the black, electronic unit. I did this a few months ago and it saves a lot of time vs changing out the distrubution block as well and then neeing to bleed the system.
I got mine off a wrecked car...I heard to make sure it it's the proper channel (3 or 4), but I can't confirm this. Fairly easy fix.
Yeah I know what you are saying. I actually bought one from someone on here, but it wasn't the right one. I didn't figure out it wasn't the right one until I took it apart. Before I took it apart I was afraid that I was going to have to take the brake lines off and bleed the ABS system, but it's actually pretty easy; now if I can find the proper EBCM
